User defined symbols
Does anyone know how to make user defined symbols. I want to create somethind kinda simular to a DELTA with a letter or number in it. I cant find anythind in the help files.
Robert
Robert
RE: User defined symbols
NX3 or NX4
Al Griego
Al Griego
Did you search for 'user defined symbols' in the NX4 documentation? I did and got all the info you need. Search on the phrase above, without the quotes then select result #5 from the results that appear. It should say "User-Defined Symbols". Click the link and everything you need to know should display.
Now, with all of that said, are you just wanting a triangle with a number inside it (centered)? If so, take red5cad's advice and use an ID Symbol. You can make the origin relative to Text if needed and it will behave as if it's part of the Text block.
Since the advent of the Origin tool, I've completely quit using User-Defined Symbols.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
on a side note: I did a search on here (eng-tips) and nothing came up. infact, nothing I search for ever shows up. what am I doing wrong?
