How to change colors on imported DWG files?
SP3.1 2007
I have opened a DWG file in Solidworks. The parts were drawn on layers and hence differant colors. How can I change the colors in Solidworks to be able to see the parts and dimension them? (Yellow on white background sucks.)
RE: How to change colors on imported DWG files?
You can create a layer that is black, select everything and put them on that layer so you can see them.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
You could also change the color of that layer.
