Incompatible type?(API problem)
I have got macro in VBA for SW which takes selected point,puts on this point new coordinte system and later should use this coordinates to another part of program.But it still sees some problem about incompatible type of variable.
below i putted my code:
***After clicking the button:
Private Sub cmd1_Click()
Blo.Hide
Dim swApp                   As SldWorks.SldWorks
Dim swModel                 As SldWorks.ModelDoc2
Dim swSelMgr                As SldWorks.SelectionMgr
Dim swSelData               As SldWorks.SelectData
Dim bRet                    As Boolean
Dim swFace                  As SldWorks.Face2
Dim swPoint                 As SldWorks.Vertex
Dim vPoint                  As Variant
Dim swSkCofG                As SldWorks.SketchPoint
Dim seltype                 As Long
Dim FormatedX               As Single
Dim FormatedY               As Single
Dim FormatedZ               As Single
Const MINSELECTIONS = 1
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swSelData = swSelMgr.CreateSelectData
Do
swModel.ClearSelection2 True 'clear selections
MsgBox " Select VERTEX where You want to place Coordinate system. ", vbOKOnly Or vbInformation
    While swSelMgr.GetSelectedObjectCount < MINSELECTIONS
        DoEvents   'Wait for user selection
    Wend
seltype = swSelMgr.GetSelectedObjectType2(1)
Loop While (seltype <> SwConst.swSelectType_e.swSelVERTICES)
    Set swPoint = swSelMgr.GetSelectedObject5(1)
    vPoint = swPoint.GetPoint
    swModel.Insert3DSketch2 False
    swModel.SetAddToDB True
    Set swSkCofG = swModel.CreatePoint2(vPoint(0), vPoint(1), vPoint(2))
    'Definition of the Relative X,Y,Z
    FormatedX = Format(vPoint(0) * 1000, "#####0.0000")
    FormatedY = Format(vPoint(1) * 1000, "#####0.0000")
    FormatedZ = Format(vPoint(2) * 1000, "#####0.0000")
    GivingInformation.setRelativeX (FormatedX)
    GivingInformation.setRelativeY (FormatedY)
    GivingInformation.setRelativeZ (FormatedZ)
    swSelData.Mark = 1
    bRet = swSkCofG.Select4(True, swSelData)
    bRet = swModel.InsertCoordinateSystem(False, False, False)
    MsgBox " The Coordinate system has  been definied at the selected place. ", vbOKOnly Or vbInformation
CleanUp:
    Set swFace = Nothing
    Set swSurf = Nothing
    Set swSelMgr = Nothing
    Set swModel = Nothing
    Set swApp = Nothing
    Blo.Show
Call Info
End Sub
***In GivingInformation module there is:
Dim RelativeX As Single
Dim RelativeY As Single
Dim RelativeZ As Single
Public Sub setRelativeX(variable As Single)
RelativeX = variable
End Sub
Public Sub setRelativeY(variable As Single)
RelativeY = variable
End Sub
Public Sub setRelativeZ(variable As Single)
RelativeZ = variable
End Sub
Function Info()
If RelativeX = 0 & RelativeY = 0 & RelativeZ = 0 Then '***HERE IS THE PROBLEM
MsgBox "Something"
Else
MsgBox " X = " & RelativeX & vbCrLf & " Y = " & RelativeY & vbCrLf & " Z = " & RelativeZ
End If
End Function
Every time on line "If RelativeX=0 & Relat..." there message that type is incompatible.I have no idea how I should solve it.If anybody could help me i will be grateful.
RE: Incompatible type?(API problem)
You need to use the word "And", not "&".  "&" is only used for concatenating strings.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
It works!
Simply thing,but very important.
Many thanks for your advice TheTick!
