Driving variable table values with excell?
Hi Im trying to drive an variable table value with an excell spread sheet. I can not get this to work properly.  Has anyone done this succesfully?  Any help would be apreciated.
thanks.
RE: Driving variable table values with excell?
yes, done it, but the SE-Help has a good explanation I think. Get to
SE--> Help --> Index and under variables you will find this topic
   Create a Variable with a Link to a Spreadsheet
You can't, however, drive a 'driven variable' from a spreadsheet.
Those variables have a grey background.
 dy
Hi
Yes, I have done this recently with very good success. Once you get the hang of it it is very easy.
- right click on your Excel cell and select COPY.
- open your variable table in SE and select the cell in the FORMULA column of the variable you want to drive.
- right click and select PASTE LINK (not paste).
If this doesn't work let me know and i will go to my workstation and run through the sequence - i my have forgotten to mention something.
A couple of things to remember:
- open the spreadsheet before you open the SE model.
- changing the name of the spreadsheet, worksheet, or moving the cell will break the link. (it is possible to change the path revision manager however)
- if you think you will need to move cells, name the cells first and the link will be ok.
- not essential but best to keep the spreadsheet in the same folder as the assembly.
I have used this process to build a user interface that works very well and i also found it easier to link values to the spreadsheet rather than between variables tables.
roger
Thanks I got it now, It seems to work very well.  I think this will be a very usefull tool for me.
thanks again.
