Shaft Torsion Calculation
I am looking for a formula to calculate shaft diameter needed.
The shaft is 20 feet long with one end stationary with no load and the other end has a 6500 in/lb load @90deg. I am looking for the angular deflection at the loaded end to determine the proper shaft diameter needed.
Thanks for your help.
Fred
Fred
RE: Shaft Torsion Calculation
Dr Lemaster's Lecture at UT.
http://ww
θ = TL/GJ
where
θ = shaft angular deflection in radians
T = applied torque in N·m
L = shaft length in m
G = shear modulus in N/m2 (steel is 80·109
J = polar moment in m4 (J = π·r4/2 for a solid cylinder)
If you solve for radius r, you get about 12 mm; thus, your shaft diameter should be about 24 mm, or about 1 inch.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The equation I provided is correct. If T, L, and G are fixed, then you must increase J (which really is only r multiplied by a constant) to result in the smallest deflection. Your choice of shaft (2-7/16 in) results in an angle much smaller than one degree.
Cory
My application requires me to turn the shaft at one end (very low, 18 rpm) with a gearbox to turn a sprocket at the other end to lift 6500 in/lbs. The shaft is anchored along its length with 5 pillow block bearings to support it. Two of the pillow blocks will be mounted very close to the ends. Under a static load, I am looking for as little shaft "twist" as possible. The shaft will see little to no shock load and the gearbox will be driven with a drive to start/stop it slowly.
You'll have to be a bit careful lining up all these bearings.
