Power Splitter
Power Splitter
How do I measure the loss on one port of a four way 0 degree 50 ohm power splitter? Do I have to terminate the other ports? Or should I leave the other ports w/ no connection?
RE: Power Splitter
RE: Power Splitter
One other slightly less accurate way is if you have two identical units and simple (equal phase equal loss) adapters that can connect them together. Connect the two together and measure in one and out the other, divide loss by 2 (in dB).
kch
