Load Calc for 3/8" x 8" x 14' Flitch Plate
Can someone give me the load calc for a 3/8"x8"x14'span Flitch plate between 2 2x10's
RE: Load Calc for 3/8" x 8" x 14' Flitch Plate
thread507-188799: Flitch Plate Beam Design Article
This article is a good source.  The rest is basic mechanics of materials.  You check the transformed section as wood and as steel for both bending as shear and use the one with the least strength for design.
Thanks for your post..
B
Check out www.beamchek.com.  Their software will handle this
and is about $150.00
Check that - I just rechecked it and it does not do exaclty what your are looking for .... Sorry
StruCalc v7.0 will do flitch plate design with most any wood type.  I haven't used that module yet to comment on the results.
Jim
JWILSON, I have struc Calc v6.0.  Is it worth the money to upgrade it?
http://www.swijetty.com
Sea Water Intake and Jetty Construction
