Measure Tool Problem
SWX 2206
Hope fully this is is pretty simple question, I just can't figure it out.
I have a checker here who sometimes needs to open the Solidworks 2d drawings and measure some distances.  I showed him how to use the measure tool but there is one instance where we have a problem.  He wants to measure the distance from the center of the hole to a face is at and angle (not horiz. or vert.)  He selects the circle and the line and what he gets is a the distance from the center of the circle to his selection point on the line.  Not the distance that would be from the center of the circle perpendicular to the line.  I hope this makes sense.
RE: Measure Tool Problem
diamoncat,
I just posted a thread a few days ago that deals wirth a similar problem. Check it out.
Tape Measure Tool
thread559-192600: Tape Measure Tool
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
Intel 2 Duo Core, 2GB RAM
nVida Quadro FX 3450 512 MB
Thanks but my checker knows nothing about Solidworks other than how to measure so constructing lines would he alot of work for him.
We just need to measure the distance from the center of a hole perpendicular to a line.  There should be a way to open the measure command, select a line which is on that angle to set the angle of the measure coordinates, then do your measuring.
Is it possible to just convert entities for that feature on the drawing to allow the measure command to operate directly on the drawing?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
It doesn't work with the convert entities either.  The funny thing is that if I just make a 2d sketch off to the side, on this drawing sheet, which consists of a circle and an angled line..When I used the measure command on that, I DO get the proper perpendicular dim.
My same issue occurs when I have two holes that are in an angled plate.  If I want the distance between them that is parallel to the edge of the plate they are on, and not horiz or vert, I get the same problem.  I need to somehow be able to set the coords before measureing.
Have you tried using edrawings?
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
