Deviatoric Test Data
Dear forum members,
I'd appreciate if anyone can shed some light on rubber modelling in abq CAE. I'm modelling an elastomer gasket using *Hyperelastic, Marlow. There are several sets of test data which I have tried to include in my inp deck, namely uniaxial, biaxial, planar and volumetric test data.
When running the inp deck, I received this error msg (which led to job termination)
***ERROR: ONLY ONE SET OF DEVIATORIC TEST DATA OPTION CAN BE USED WITH MARLOW
           HYPERELASTICITY
 ***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
Is this indicative of data overkill in the inp deck? Does this mean I have to remove some of the data?
Appreciate the help.
thanks,
jo
