impulsive load
impulsive load
impulsive load
hi,
I have a problem. I use femap with nastran (linear) and I have to solve a problem where a force F load the structure for t ms ( I know F and t). Is there a way to use linear analysis for resolve this problem?
thanks
sirx
RE: impulsive load
Hi
Linear analysis should work provided that the material has linear behaviour. But you have to use a transient (time stepping) solution. Even if the material is nonlinear the linear solition is a good starting point.
Good Luck
Thomas
