Gas Turbine Efficiency
Anyone know what is the highest industrial & aeroderivative type GT efficieny in the market now?
ppm
ppm
RE: Gas Turbine Efficiency
Here is a plot that indicates Brayton Cycle (Gas Turbine) ideal thermal efficiency:
Gordan
http://engware.i-dentity.com
GE LM2500 (27.7 MW) is 40.7%
Zorya-Mashproekt (never heard of them) has a UGT 15000 STIG (25 MW) at 42.0%
saludos.
a.
The published numbers are Output and Heat Rate.
In metric units, the efficiency (per unit) can be calculated as:
3600/Heat Rate
saludos.
a.
