Concrete Slab Design on top of Silo
Need help.  Does anyone know of a design reference for the design of a concrete slab that will be supported by concrete walls?  We have to design a slab for a 32' diameter silo.  The slab will support a water tank.
RE: Concrete Slab Design on top of Silo
Will the slab be uniformly loaded or with concentrated loads?
You might find some formulas for bending moments in a round slab in Roark. I would probably take a more simplified approach by assuming a square box of size 0.9 D and then designing rebar in two direction. This should work for uniform load.
For concentrated loads, I probably would recommend using an FEM approach.
