Copper to Copper bonding
I am looking for an adhesive or bonding compound for bonding copper plates together.  The adhesive must withstand temperatures in the 250 degree range.  Thanks
Vade
RE: Copper to Copper bonding
Is silver soldering acceptable?  Also, you didn't say if it is 250 °F or 250 °C.
Apart from the obvious solution, as vade says, and without knowing wether you require an electrical bond there is this adhesive:
http://www.masterbond.com/nrep21ht.html
Bluexcell
# . #  Up all night again ....
Well if it wasn't for the fact that the material is copper, I would suggest RTV.  Unfortunately RTV (up to 500 - 600F) is from the silicone family.  It will free acetic acid as it cures and corrode the copper.  If it is 250C you cannot use an organic compound and are limited to the inorganics.  I'm going to side with the first two gentlemen.
John Schrock
www.glubie.com
