UNDER DEFINED SKETCH
All, I have a under defined sketch and I can not figure out why.  I have no blue lines or points I have tried to move every line, point and curve and can not find the culprit.  Is  there any other way to find the unconstrained part.
Brian
SW2006 SP 5.1
Brian
SW 2006 SP 4.1
RE: UNDER DEFINED SKETCH
You can go to Tools\Dimension\Fully Define Sketch and see what gets added.
Dan
www.eltronresearch.com
Thanks "That was easy"
Brian
Brian
SW 2006 SP 4.1
Eltron,
What am I missing here?  There is no "Fully Define Sketch" under Tools/Dimension.
Are you possibly running '07 ?
Stugots
Mechanical Designer
SW '06 SP5.1
It's in SW07
Be sure that it is not hidden by choosing the customize menu option (Tools/Dimension/Customize Menu).  If it is not there, then it may not be available in SW06, but I thought that I was using it last year.  By the way I am currently using SW07 SP4.
Dan
Stugots,
It is called "autodimension" in 2006.
Brian
Brian
SW 2006 SP 4.1
