Smart Components question
Hi all. I want to make a smart component of an 80/20 Anchor Fitting (Banjo). It is just a blind hole near the end of an extrusion. I've got a handle on how to do this, but the sticky part is, I would like to drag the 'smart' banjo into the assembly (so the B.O.M. is correct) and have the coresponding hole be pushed back to the frame at the part level.
You need to understand that the frame itself is a multi-body part, a weldment. I find that to be a very efficient way to make framework. The cut list is a most excellent feature.
Any thoughts??
Any thoughts??
RE: Smart Components question
Dan
www.eltronresearch.com
Stugots
Mechanical Designer
SW '06 SP5.1
When I set it up as a Smart Component it does push the coresponding cut feature back to the weldment part level. Very nice. But....What it does not do is prompt me for the edges to dimension the hole from. I have to fully mate the component each time.
I would like to drop the hardware into the assembly and have it "smartly" bring in the mates that I set up when I made the smart component in the first place. I thought this might work similar to the way that a Library Feature part works. Anyone know if a Smart Component can also be a Lib. Feat. Part?
Thanks for your time.
