VAV system for Winter Heating & Demand Ventilation
I have been involved in designing a small one storey building having multizone areas. Can I use a roof top package unit having gas fired heat exchanger and cooling coil and terminal VAVs (without reheat) to control the individual zones during winter by modulating the airflow (similar during cooling period) to maintain the zone temp. The supply air temp shall be fixed (or resettable). Heating boiler is not an economical solution for such small application and I do not want to use terminal electric heating (Baseboard or VAV reheat) either. Besides if I intend to utilize demand ventilation concept to modulate the economizer damper based on CO2 sensor input how can I integrate this with the design mentioined earlier?
Apprciate your thoughts.
RE: VAV system for Winter Heating & Demand Ventilation
