Feature manager
Feature manager
Feature manager
Why do two feature managers appear sometime? What is the purpose of two feature managers option? (I pulled one of the feature managers on to the other to see one, which was done on one of the book examples. But, it keeps coming up many times. There should be a good reason for this). Thanks.
RE: Feature manager
A question for each Feature Manager ... I guess?
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
RE: Feature manager
Can you split threads into 2 threads, just like you can split the feature manager?
RE: Feature manager
You can perform different functions within the feature manager.  Having it split lets you access two of those functions at the same time.
If it keeps popping up, then you may be hitting a shortcut key assigned to turning it on, or your settings are default to split FM.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
