harmonic solution time steps
Hi All,
I am currently working on a harmonic solution in ansys.
I am a novice into ansys, actually first time user. I am working on a tube that has a highfrequent ac current running through its outer layer. Induced by a coil. (skineffect)
I am able to plot the current density against the radius (depth) of the pipe. However I want a solution in more time steps throughout the harmonic wave. I am now trying 3 days and can't get ansys to give me different solutions of the induced current evolving in time. The frequency I use is 6 Mhz.
could anyone help me out ?
I would be very thankfull because I need this simulation results to build a measurement cell.
The code I use :
//prep7
/pnum,kp,1
/pnum,line,1
/pnum,area,1
/pnum,mat,1
! Constants
*SET,r_i,0.004 !tube inner diameter
*SET,r_o,0.005 !tube outer diameter
*SET,r_sp,0.010 !Coil radius
*SET,h_ox,20E-6 !oxide layer thickness
*SET,h_slg,20E-6 !slagging layer thickness
*SET,h_sp,0.0008 !coil thickness
*SET,w_sp,0.008 !coil width
*SET,d,0.005 !coil displacement from edge
*SET,A,0.05 !environment length
*SET,L,0.06 !tube length
*SET,Ex,0.02 !excentricity from origin
*SET,a_sp,h_sp*w_sp !Coil cross section area
*SET,N,10 !Number of coil turns
*SET,i,1 !Current in z-direction
*SET,F,0,95 !Coil Fill factor
! Geometry
rectng,EX,EX+L,0,r_i ! Water region
aatt,1
asel,none
rectng,0,2*EX+L,0,A ! Air region
aatt,4
asel,none
rectng,EX,EX+L,r_i,r_o-h_ox ! Steel
aatt,2
asel,none
rectng,EX,EX+L,r_o-h_ox,r_o ! Oxide film
aatt,3
asel,none
rectng,EX,EX+L,r_o,r_o+h_slg ! Slag film
aatt,3
asel,none
rectng,EX+d,EX+d+w_sp,r_sp,r_sp+h_sp ! Coil1 (links)
rectng,EX+L-d-w_sp,EX+L-d,r_sp,r_sp+h_sp! Coil2 (rechts)
aatt,5
asel, none
allsel ! Subtraction areas
asba,2,ALL,SEPO,,KEEP
asel,s,,,8
aatt,4
asel,none
allsel
asum, default
*get,a,area,,area
asel,none
allsel
nummrg,kp,1.E-6
! Elements definition, Material properties, Real constants, Meshing
et,3,53,0,,1 ! Oxide film
type,3
mp,murx,3,1
mp,rsvx,3,1.0E-7
lsel,s,line,,11
lesize,all,,,150
allsel
lsel,s,line,,15
lesize,all,,,150
allsel
lsel,s,line,,14
lesize,all,,,25
allsel
lsel,s,line,,16
lesize,all,,,25
allsel
asel,s,mat,,3
mshape,0,2d
amesh,4
allsel
et,2,53,0,,1 ! Steel
type,2
mp,murx,2,1
mp,rsvx,2,1.0E-7
lsel,s,line,,3
lesize,all,,,200
allsel
lsel,s,line,,11
lesize,all,,,200
allsel
lsel,s,line,,10
lesize,all,,,40,1/20
allsel
lsel,s,line,,12
lesize,all,,,40,20
allsel
asel,s,mat,,2
mshape,0,2d
amesh,3
allsel
et,5,53,2,,1 ! Coil 1 (links)
type,5
mp,murx,5,1
mp,rsvx,5,1.78E-8
R,
lsel,s,line,,22
lesize,all,,,10
allsel
lsel,s,line,,24
lesize,all,,,10
allsel
lsel,s,line,,21
lesize,all,,,30
allsel
lsel,s,line,,23
lesize,all,,,30
allsel
asel,s,mat,,5
amesh,6
r,1,2*a,n,,-1,1
allsel
et,6,53,2,,1 ! Coil 2 (rechts)
type,5
mp,murx,5,1
mp,rsvx,5,1.78E-8
lsel,s,line,,26
lesize,all,,,10
allsel
lsel,s,line,,28
lesize,all,,,10
allsel
lsel,s,line,,25
lesize,all,,,30
allsel
lsel,s,line,,27
lesize,all,,,30
allsel
asel,s,mat,,5
amesh,7
r,1,2*a,n,,-1,1
allsel
et,1,53,0,,1 ! Air(/Water)
type,1
mp,murx,1,1
mp,rsvx,1,3E13
lsel,s,line,,1
lesize,all,,,200
allsel
lsel,s,line,,3
lesize,all,,,200
allsel
lsel,s,line,,2
lesize,all,,,20
allsel
lsel,s,line,,4
lesize,all,,,20
allsel
asel,s,mat,,1
mshape,1,2d
amesh,1
allsel
et,3,53,0,,1 ! Slag layer
type,3
mp,murx,3,1
mp,rsvx,3,1.0E-7
lsel,s,line,,15
lesize,all,,,150
allsel
lsel,s,line,,19
lesize,all,,,150
allsel
lsel,s,line,,18
lesize,all,,,35
allsel
lsel,s,line,,20
lesize,all,,,35
allsel
asel,s,mat,,3
mshape,0,2d
amesh,5
allsel
et,4,53,0,,1 ! Surroundings (Air)
type,4
mp,murx,4,1
mp,rsvx,4,3E13
asel,s,mat,,4
mshape,1,2d
amesh,8
allsel
! Boundary conditions
asel,s,mat,,2,3,1,1 ! Coupling VOLT DOFs for conducting
nsla,s,1 ! regions (steel & oxide film)
cp,1,volt,all
allsel
asel,s,area,,6,6,1,1 ! Coupling CURR DOFs for coil 1
nsla,s,1
cp,2,curr,all
allsel
asel,s,area,,7,7,1,1 ! Coupling CURR DOFs for coil 2
nsla,s,1
cp,3,curr,all
allsel
nsel,s,loc,y,0
d,all,az,0 ! flux-parallel condition (axial line)
allsel
csys,0
fini
! Solution
/solu
antype,harm
esla,s,1
bfe,all,vltg,,1 ! voltage load
allsel
outres,all,all
autots,on
deltime, 0.1E-6
harfrq,0,6E6
solve
/post1 ! Post-processing
allsel
asel,s,area,,3,5,1,1
PLESOL,JT,SUM,0 ! Total current density in steel
!& oxide film
ETABLE, ,JT,Z
PATH,cutline,2,30,30,
PPATH,1,0,0.2900000E-01,0.502E-02,0,0,
PPATH,2,0,0.2900000E-01,0.472E-02,0,0,
PDEF, ,ETAB,JTZ,AVG
/PBC,PATH, ,0
PLPATH,ETABJTZ
PRPATH,ETABJTZ
/EOF
The code I use :
//prep7
/pnum,kp,1
/pnum,line,1
/pnum,area,1
/pnum,mat,1
! Constants
! Geometry
aatt,1
asel,none
aatt,4
asel,none
aatt,2
asel,none
aatt,3
asel,none
aatt,3
asel,none
aatt,5
asel, none
asel,s,,,8
aatt,4
asel,none
allsel
asum, default
*get,a,area,,area
asel,none
allsel
nummrg,kp,1.E-6
type,3
mp,murx,3,1
mp,rsvx,3,1.0E-7
lsel,s,line,,11
lesize,all,,,150
allsel
lsel,s,line,,15
lesize,all,,,150
allsel
lsel,s,line,,14
lesize,all,,,25
allsel
lsel,s,line,,16
lesize,all,,,25
allsel
asel,s,mat,,3
mshape,0,2d
amesh,4
allsel
type,2
mp,murx,2,1
mp,rsvx,2,1.0E-7
lsel,s,line,,3
lesize,all,,,200
allsel
lsel,s,line,,11
lesize,all,,,200
allsel
lsel,s,line,,10
allsel
lsel,s,line,,12
lesize,all,,,40,20
allsel
asel,s,mat,,2
mshape,0,2d
amesh,3
allsel
type,5
mp,murx,5,1
mp,rsvx,5,1.78E-8
R,
lsel,s,line,,22
lesize,all,,,10
allsel
lsel,s,line,,24
lesize,all,,,10
allsel
lsel,s,line,,21
lesize,all,,,30
allsel
lsel,s,line,,23
lesize,all,,,30
allsel
asel,s,mat,,5
amesh,6
r,1,2*a,n,,-1,1
allsel
type,5
mp,murx,5,1
mp,rsvx,5,1.78E-8
lsel,s,line,,26
lesize,all,,,10
allsel
lsel,s,line,,28
lesize,all,,,10
allsel
lsel,s,line,,25
lesize,all,,,30
allsel
lsel,s,line,,27
lesize,all,,,30
allsel
asel,s,mat,,5
amesh,7
r,1,2*a,n,,-1,1
allsel
type,1
mp,murx,1,1
mp,rsvx,1,3E13
lsel,s,line,,1
lesize,all,,,200
allsel
lsel,s,line,,3
lesize,all,,,200
allsel
lsel,s,line,,2
lesize,all,,,20
allsel
lsel,s,line,,4
lesize,all,,,20
allsel
asel,s,mat,,1
mshape,1,2d
amesh,1
allsel
type,3
mp,murx,3,1
mp,rsvx,3,1.0E-7
lsel,s,line,,15
lesize,all,,,150
allsel
lsel,s,line,,19
lesize,all,,,150
allsel
lsel,s,line,,18
lesize,all,,,35
allsel
lsel,s,line,,20
lesize,all,,,35
allsel
asel,s,mat,,3
mshape,0,2d
amesh,5
allsel
type,4
mp,murx,4,1
mp,rsvx,4,3E13
asel,s,mat,,4
mshape,1,2d
amesh,8
allsel
cp,1,volt,all
allsel
nsla,s,1
cp,2,curr,all
allsel
nsla,s,1
cp,3,curr,all
allsel
nsel,s,loc,y,0
allsel
csys,0
fini
! Solution
/solu
antype,harm
esla,s,1
allsel
outres,all,all
autots,on
deltime, 0.1E-6
harfrq,0,6E6
solve
allsel
!& oxide film
ETABLE, ,JT,Z
PDEF, ,ETAB,JTZ,AVG
/PBC,PATH, ,0
PLPATH,ETABJTZ
PRPATH,ETABJTZ
/EOF
RE: harmonic solution time steps
I would recommend you to read the Ansys help Chapter 4. Harmonic Response Analysis for the basics.
Then you will know how to define the solution options for a harmonic analysis. For example you don't use the command DELTIM. Use instead NSUBST.
Anyway I don't understand why you have set deltim,0.1E-6 where the frequency range is harfrq,0,6E6. Even if deltim would work, you would get a total of 60e12 time steps!
Alex
Thx I found it out :)
Another problem does anyone now how to pick up the induction in the receiver coil, one I use to induce the current in the bar, the other one is to pick it up.
grtz Wouter
