Huth Formula for Fastener Flexibility
I asked this in another forum as well. But I thought a discussion on different methods of determining fastener flexibility may begin here. I have been using Tate and Rosenfeld and recently read the paper by Huth and felt that since his formula was determining lower compliance that the increased stiffness would produce more conservative results. However, unlike the T&R, it appears that the Huth is dependent on which element you make T1 or T2 (for single shear joints).
My question from the other forum:
In the Huth formula for fastener flexibility (Huth on Influence of Fastener Flexibility). If you have a single shear joint with two different sheet thicknesses (t1 and t2), which sheet thickness do you utilize for t1 and t2(i.e. the thin sheet for t1 and the thicker sheet for t2 or vice versa). Due to the 1/2nt2E3 factor in the right hand side bracket, this multiply by two in the denominator can make a difference depending on which thickness you utilize. Also, since this equation is also good for double shear with n=2 in lieu of 1, I am wondering if this 2 is a typo. My example: I have a 0.056" thk skin doubler on a 0.050" thk skin, I am obtaining my fatigue stress from the original skin which I am making t1, the doubler, which is thicker, is then t2.
Now I understand that in the grand scheme of things this difference of 0.050 and 0.056 is going to have an insignificant affect on the calculation. Additionally, for most joint designs, the two parts should be close in thickness which would also provide an insignificant change. However, it would be nice to now which way the formula was inteneded.
RE: Huth Formula for Fastener Flexibility
I also searched Knovel for other instances of Huth on flexibility in the literature, but came up empty.
Postupka, S.; Kühweg, A.; Arendts, F.J.; “Determination of the Bolt Flexibility of CFRP-Joints” ECCM-8, 1998, pp. 61-68
The original Huth equation (in German) lists the flexibility as:
C = ((t1+t2)/(2D))^a + b/n(1/(t1E1) + 1/(nt2E2) + 1/(2t1E3) + 1/(2nt2E3))
For single shear, n = 1
The first equation listed above is missing a 2 in the (tpEb) term. I’m not sure why it’s different than the original Huth equation. This equation is used a lot – is it a mistake?
FYI: The Tate paper is available here:
http://nt
Some time ago i found in internet a good work named "Defining a standard formula and test method for fastener flexibility in lap joints" by Geoff Morris ( TU Delft ).
It may be useful for you.
Cheers !
Mohr
P.S: If you can not find it let me know and i will send you
a copy of this paper.
I believe:
t1 = tp (the thicker member)
t2 = ts (the thinner member)
This gives the lower compliance and thus a more conservative pin load than the opposite.
to make things more confusing, we wrote our program using the variable ti for inner and to for outer!!
Mohr,
thanks, I found the paper, didn't have time to review it thoroughly yet. I am generally a little cautious about using someone's thesis without first going through and verifying everything first.
You are right to check the thesis but in this particular case it was checked by means of test.
Cheers
The second to last quotient reads: 1/(n*t1*E3) The n should be replaced by a 2 and read: 1/(2*t1*E3).
Using the equation from the ASTM paper, you get a different spring contest based on your selection of which thickness is used for t1 or t2.
I have the original paper in German and I assume the author or the ASTM paper made a typo since he doesn't address his deviation from the German paper.
Huth, Heimo, “Zum Einflub der Nietnachgiebigkeit mehrreihiger Nietverbindungen auf die Lastübertragungs- und Lebensdauervorhersage,” LBF Report No. FB-172, dissertation, Technische Universität München, Munich, Germany, 1984.
Correct equation is...
C=((t1 + t2)/2d)^a x (b/n) [ 1 /(t1 E1) + 1 /(n t2 E2) + 1 /(2 t1 E3) + 1 /(2 n t2 E3) ]
Do you have a copy of the German paper, or can you point us to one?
I note your version of the equation would still give different values (at least for double shear, n=2) depending where you put t1 and t2 due to the n in the second and fourth terms of the second group. Can you verify?
My thinking is this - a joint has only one true stiffness; therefore for a single shear joint where you put t1 or t2 into an equation should make no difference in calculating K. Flipping the joint over, so to speak, shouldn't make a difference, it just doesn't make sense.
I challenge, with respect, those who've reported test results saying t1 should be the thinner plate to explain how they created the two different test configurations for a single shear joint (mohr?, 737?).
Now, for double shear joints this gets a bit more complicated. Since the equation only has t1 and t2 I'd assume that the inner sheet is one thickness and the two outer sheets are assumed to have another - equal - thickness. But the question is which is t1 and which is t2? Looking at (what I'm accepting as the) correct form of the equation, the n term (2 for double shear) is only associated with the t2 term in the second group. Since I'm assuming bearing is the predominant factor being calculated by those terms, it seems logical to assume the factor being doubled would be the term associated with the outer sheets (since there are two of them). Therefore I believe t2 refers to the outer sheets, and it only makes sense to distinguish between t1 and t2 in the double shear case.
This provides a tidy explanation for the nomenclature in 737's program which refers to inner and outer; and unfortunately provides a compelling argument that using the ASTM formula is incorrect.
that'd be the sign for the rest of us mortals to stone the snot out of ASTM ...
Due to this discrepancy, I have just continued to utilize R&T, however, I am going to try an obtain a copy of the original Huth report in order to possibly utilize the Huth formula in the future (properly).
The Huth formula it’s not the only way to get fasteners stiffness, there are also some different approaches to the problems with different results also.
-Swift (Douglas)
-Tate & Rosenfeld
-Huth, Schwarmann (Airbus)
-Vought
-Grumman
-Delft University
Which one gives the right answer? That’s the question
Take a look to the attached document to see the details of every formula (I hoppe it works)
Veneno
They all give the right answer, at least for the data they were based upon. Thats the key really. So the method you should use is the one that is agreed with the powers that be.
there are an enormous number of varibles that affect different fastener geometries differently, and each author has assumed the shape of the interaction and which factors are going to be most significant. if you look at the different solutions they work in contradictory ways and give wildly different results; at best each matches a set of data and one or another is preferred by whoever is looking over your work (as 40818 says, "the powers that be").
i think the important point is that whichever formula you use the results doesn't change in a really significant way. if you have the time use a couple of formulas, see how the results vary ... if it is something that is really critical and you're getting questionable results, i'd then suggest a test.
A few years ago, in my internship, I made some test in Nastran simulating fasteners joining two sheets, with RBE (rigid elements), CBUSH (6 dof springs), CBAR (beam elements), and CFAST (connector elements with 6dof springs), I also use different model to get the fasteners stiffness (only for CBUSH & CFAST).
In general terms, the stresses in the shell are quite similar in every model, but the stress in the surrounding areas of the fastener and the loads carried by the fasteners itself varies widely. I didn’t make any experimental test to validate the model
So that’s why I ask again, which one gives the right result?
veneno
i have modelled joints with CELAST springs; i chose the douglas model 'cause it was conveniently cloe to hand, and was happy in my work ... i'm not going to say that the douglas model is superior to the others, but it is an industry standard so it has some "street cred."; any of the other standard models would have worked out equally well.
