Convergence problem
Convergence problem
Convergence problem
I m modelling the rolling elements of  a bearing by two non linear traction springs between the center of curvatures of the raceways..
Moreover, each center of curvature is coupled to contact zone'(modelled by rigid shells) by a rigid beam .
I have divergence and the following message
AVERAGE MOMENT                      3.43       TIME AVG. MOMENT       3.43
 LARGEST RESIDUAL MOMENT            2.221E-03   AT NODE      73858   DOF  5
 LARGEST INCREMENT OF ROTATION      0.220       AT NODE      36128   DOF  5
 LARGEST CORRECTION TO ROTATION     0.215       AT NODE      36128   DOF  5
          ROTATION CORRECTION TOO LARGE COMPARED TO ROTATION INCREMENT
Rotation correction.
I tried to decrease the incrementation to 1E-05, and i still have the same probleme.
Any ideas?
RE: Convergence problem
Hi.
Could it be that your rotation tolerance setting is too low? You could try relaxing it. Just a guess here.
regards,
jo
How do i adjust the rotation tolerance?
Use *CONTROL
I use
*CONTROLS, PARAMETERS=FIELD, FIELD=DISPLACEMENT
 ,100.0
This sets the displacement ctrl to 100% instead of the 5% default. The values are force tol, disp tol.
I'm sure the documentation has some instructions about rotation ctrl. Try looking up the *Controls.
