Multi-analysis and transfer
Hi everybody
Is it possible to program succesive simulations, by changing one parameter for each simulatiom, and
Is it possible to transfer the result data from Abaqus to Matlab for example ?
Nadir
RE: Multi-analysis and transfer
see abaqus v6.7 manual Section 15.1 for parameter for each simulatiom.
can u print the results in report file and cut and paste into the mathlab?
I can do it but as I have almost 50 parameters, it will take a long time
you can run the script file to run all input files in the same directory and you can put as many files as you like. They will  run the file one by one.
What parameters you want to change? If this is the loads and b.c., you can edit the input files and change the paramters in notepad.
Script file can be found in abaqus Q&A in their site. Of course you need to have their license to login.
You do not need to change the parimeter one by one.
In abaqus v6.7 manual Section 15.1.
It should show you how to change the parimeter with a few option like mesh, cross.
It allow you to change the parimeter in the order from x to y with increment of z.
Also you can have 50 different parimeter with the above and analysis all the combination by changing the type to mesh or cross (need to check the type).
In terms of resulting. I would write a python script to handel it.
thans guys
