Leakage tests using air
Hi all,
Has anyone performed leakage tests with air on hydraulic/fuel/water system after installation? Our contractor insists that a small amount of air leakage occurs in pumps/valves/closures, and a threshold is necessary to define the amount of leakage to say that test is failed. But we've always performed leakage tests with water and there was no threshold: any leakage was a failure. I assume that the leakage from equipment is an equipment design property, but can an air leakage happen from pipe connections, couplings etc?
RE: Leakage tests using air
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Technical Report No. 32-926
"Basic Criteria and Definitions for Zero Fluid Leakage"
by Richard S Weiner dated December 15 1966
Prepared under contract NAS 7-100
Perhaps someone has redone this report in electronic media, or software.
