"Limit Distance" mate problems
Hi Everyone,
I am having a big problem with "limit distance" mates. I have always used these in sub-assemblies and never had problems until now. Basically I have a shock absorber with a given extended and collapsed length (defined by a limit distance mate). I then have a top level assembly that contains this shock absorber as "flexible". I set a limit distance maximum and minimum, and it just changes randomly. Yesterday it would change the maximum and minimum altogether, today it just changes the "distance" value. The wierd part is that it seems to have a random maximum and minimum when moving the assembly by itself and within the top level assembly. Basically, I have tried everything possible and the values just change. Thanks for your help.
Brandon
rrshocks.com
Dell M70
RE: "Limit Distance" mate problems
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Brandon
rrshocks.com
Dell M70
