Saving as .DWG, loses hidden lines
Hi; anyone know why when I save my drawing as a .dwg, it decides to kill off all my hidden lines (and exports the dwg that way)? The only way I have of getting it to work is to save it like this, then change every drawing view on the sheet to a different view-type, and then back to "show hidden lines as dashed lines"... and re-export as .dwg. The second time around it works... pretty annoying...
Thanks!
Kyle
Thanks!
Kyle
RE: Saving as .DWG, loses hidden lines
What version and SP of SolidWorks are you using?
What software are you using to open the DWG?
Cheers,
It's a solid fix for me to re-change the views and re-save, but ... just kind of odd, obviously not normal...
