Strange Sketch Issue
I'm sure somebody will be able to answer this in 5 seconds but I can't figure out what is going on.  I create a new sketch and draw a rectangle.  I then grab the right hand vertical line and move it to the right to stretch out the rectangle but instead of the rectangle stretching the line is the only geometry that moves.  I tryed the same thing on a different PC and the rectangle stretchs like it should.  Is there an option for this that I can't find?
Thanks.
RE: Strange Sketch Issue
Try Looking at the following setting:
Tools-Sketch Settings-Detach Segment on Drag
If this setting is checked then you will experience the current behavior you are having.
Best Regards,
Jon Knabenschuh
Gemini CAD Solutions
http://www.geminicadworks.com
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2007
Thanks CADGemini, you sent me to the right place.  It wasn't the "detach segment on drag" but it was the "no solve move" that was giving me the problem, I am not sure how the two differ.
