Insert/Edit a General Table via VBA
I am writing a VBA macro that will populate a Solidworks General Table from a range of cells in Excel. What I would like to do is either edit an existing general table or insert a new one, via an If/Then statement. I can insert one with no problem, but I can't seem to edit/select an existing one. The funny thing is, I can get this to work with a Revision Table. Here is the If/Then statement for the Rev Table:
Dim RevTable As Object
If Not Part.GetCurrentSheet.RevisionTable Is Nothing Then
Set RevTable = Part.GetCurrentSheet.RevisionTable
Else
Set RevTable = Part.GetCurrentSheet.InsertRevisionTable(True, 0, 0, 4, _
        "W:\BLOCKS\SolidWorks Templates\Other\REVISION TABLE.sldrevtbt")
End If
This works just fine. What can I do for the general table? Any suggestions???
RE: Insert/Edit a General Table via VBA
smma,
You apparently posted this question in the SolidWorks forum too.  I posted my reply there.
SA
