Cat C9 cooling
Cat C9 cooling
I want to set up a Caterpillar C9 engine with keel cooling (on a ship). Looking at the drawings of the engine it looks like there is an HT circuit (water in 2.5" dia., water out 2.5" dia.) and an aftercooler circuit...but the drawing only shows "Seawater Inlet 2" dia."
Does anyone know the setup for the cooling? Are there 2 engine-driven cooling pumps? Why is there no aftercooling water out connection?
Thanks.
Thanks.
RE: Cat C9 cooling
The 'jacket water' pump runs glycol/water in a closed loop through the engine block and a heat exchanger. There's also an air separator/ reservoir and a pressure cap in the circuit somewhere.
The 'raw water' pump takes in seawater and pumps it through the aftercooler. The aftercooler discharges to the heat exchanger's seawater side. The heat exchanger's seawater side discharges into the exhaust gas stream through a 'wet' exhaust riser, or directly overboard if the exhaust is 'dry'.
Other variations, including keel cooling, are possible, and well documented by Caterpillar. Your engine distributor's applications engineer can bury you in documentation if he so chooses.
Mike Halloran
Pembroke Pines, FL, USA
RE: Cat C9 cooling
Is the engine you are looking at SWAC or JWAC in its stock configuration? What is the HP level and what is the exact application/duty cycle?? These would be the basics of what needs to be answered to get a more detailed answer..
Tony
Tony Athens
http://www.sbmar.com
