Excel Row Select in VBA
This works by hand and is the same as the macro recorder but it doesn't work when I try to use it.
    Range("EG3").Select
    Range(Selection, Selection.End(xlDown)).Select
The rows are filtered and the first group of rows is blank which is what prompted the double range select; it selects just the blanks including the first non-blank cell it comes to.  I can hard code a fixed range but I'd prefer something more elegant which is where you guys come in.
RE: Excel Row Select in VBA
Funny behavior, that's for sure. A quick solution is to work it backwards:
CODE
    Range("EG3").Select
    Selection.End(xlDown).Select
    Range(Selection, Range("EG3")).Select
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Thanks.
I have another ?   When the macro closes a file I get a "Do you want to keep the clipboard stuff" decision window. How do I get the code to answer that?  I don't want to pick up the mouse to click no.
Try
Application.CutCopyMode = False
at the end of the macro. This is a good habit anyway.
Cheers,
Joerd
It didn't work at the end so I put it just before each close workbook line and it worked.
Many thanks,
Roger
