Dimensions in Drawing view
Hi all.
Does anyone know of any specific bugs in SW pertaining to adding dimensions to a drawing? Imnot able to dimension the drawing that is attached to ISO dim ref's.
Any help is appreciated.
Rip
RE: Dimensions in Drawing view
Rip
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Thanks to all.....
Rip
SolidWorks 2007
SP 4.0
Through my special grapevine - -Ive heard that after people download SP 4.0, they have a few issues with dimensioning, etc.
Any word on this?
Rip
SolidWorks 2007
SP 4.0
Can you please be more specific?
No problems here dimensioning.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Heres a file containing the stuff.
Open SS-DS Carlton.SLDDRW
Try adding a dimension in this drawing that are attached to entities in sketches ISO dim ref or ISO dim ref2.
The dimension is out in space.
Rip
SolidWorks 2007
SP 4.0
Jeff Mirisola, CSWP
CAD Administrator
Chris
AutoCAD 06
I don't think it's a bug, I think that you simply can't dimension from, say, an edge of the part to a sketch that is in the part and visible in the drawing.
I tried it with some of my own models and had the same result.
You'll probably need to add sketch points in your drawing to get the dims you want.
Jeff Mirisola, CSWP
CAD Administrator
