DO-160 Sand test : criteria for compliance ?
DO-160E Sand test states that "mechanical moving features of the equipment can be manipulated ten times... " after the test to check for cloggin or binding.
Can this instruction also be applied to fans, which are moving features inside the product ? Those fans can be manipulated by poking thru' the air outlet holes, but are not accessible as such from the outside.
Your experience ?
Your experience ?
RE: DO-160 Sand test : criteria for compliance ?
