High Currents Inductors
Anyone know where I can find a 5mH inductor rated for 1,000 Amps?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: High Currents Inductors
Try Hammond, MTE, TCI.
What is your application (AC or DC)?
What type of cooling is prefered ?
http://www.j-schneider.de
and
http://www.rectifier.com
From the values given in you post I assume that you are designing an DC-current link inverter in the power range of several hundred kW. In this power range there are lots of inverters, current-link as well as voltage link, available on the market and currently voltage-link designs are replacing current link designs. So I guess you will have special reasons for designing an current link inverter yourself?. It would be intresting if you could give further details.
