Opening V4Sessions with V5
Hi all together,
I've a problem with sessions of V4.
Our customer sends us new models as a session which contains all models. The models are not send as .model, but there several .session-files which contain the geometrical information.
If I open such a file CATIA V5 crashes. Is there any posibility to open that files from V5?
I am using CATIA V5R16SP8.
CEROG
CEROG
RE: Opening V4Sessions with V5
If you have v4 , try first to clean the model (/cln) and eliminate all errors and erase/pack.
Then you can try to migrate v4 to v5 without opening CATIA v5.
Fernando
I do not have V4.
I didn't get any CATPart files while migrating that session to V5.
And that is what I wnat.
CEROG
Fernando
There must be a possibility...
Seeing this, you can estimate if you really heva geometrical information inside or not....
Fernando
There must be geometrical Information in them.
Try something like this C:\Program Files\Dassault Systemes\B12\intel_a\code\bin\ double clcik on CATUTIL.exe and run it without CATIA opened.
Good luck
Fernando
