volume calculation
volume calculation
I am looking for a non complicated and inexpensive volume calculation software/program that enables a volume to be calculated from an in-survey and an intermediated survey which overlaps a specific boundary, but I require the volume within the boundary. at present I am using auto cad lt to give me the area's and then averaging the level to calculate the volume, I am aware I could use cross section however this is time consuming and I require a quicker solution from my survey data!
thanks
olly
thanks
olly
RE: volume calculation
www.ezysurf.com
i've had a quick look and it appears to be an add on for auto cad, i'm running auto cad lt, will the limmited autocad lt work with this program? i have emailed ezysurf for clarification on this matter, thanks for the help
olly
