shear wall and pushover analysis
Hi Dear friends
I need to model shear wall for pushover analysis . Does anybody know how can I do it ?
in general, how can I do pushover analysis shear wall structure in or ETABS?
RE: shear wall and pushover analysis
You must model a wall with Frame Sections and then define Frame Nonlinear Hinge Properties. Then you assign this Hinges prop. to prior define frame sections prop.. Next step is to define Static Nonlinear/Pushover Cases...
Drile007
How can I define wall as frame section? may you please explain for me how?
for example if I define wall as column, should I define a column insted of wall with that dimension?
help me please
I could send you a large model where I done pushover analysis on old masonry structure strengthened with reinforced concrete walls.
Drile007
As you know, I model shearwall as column, but when define it, I could not understand what should I do with length of beams which are connected to the walls. because in this case, the length of beams should prolong!!!
may you please help me about this?
1) Rigid body in the area where beam crossing the wall (inside the wall)->that's right, prolong the beam to the center of the wall.
2) Regular beam outside the wall area.
PS: Sorry for my English...
Drile007
