Force Transducer Hammer / Response data into Pro M
Hi guys and gals,
This is my first attempt into doing this so excuse my ignorance. In the near future, I will be getting data from a “force transducer hammer / response” shock test. Typically ME Scope (which I have never used) is used to find the different modes of the structure. A co worker showed me some animation that was done by ANSYS that used the data from the force transducer hammer / response.
My question is, can I do the same with Pro M? If I get data from the force transducer hammer / response test, how do I import that into Pro M and see / find the different modes?
Thank you in advanced for your time and thought.
Tobalcane
"If you avoid failure, you also avoid success."
