PDMWorks using dumb file names
Not to beat this subject to death, but after quizzing many of you more experienced SW users and reading as much as I could find about this, I have decided to dumb-down my file name structure in PDMWorks to a simple 6 digit number. All file names would be a unique sequential number regardless if they are a Part, Assembly, or Drawing. Then I will use "properties" for everything else that I previously imbebded into a not so smart-file name.
A few questions??
1) How can I generate a report thats sorted by file-name only in PDMWorks? I know I can save a report as a file, import it into Excel and then sort as I wish, but it would be nice to be able to do this direct from PDM
2) It seems my next challenge will be to maintain a separate database to generate the next number/filename used! but this would not be linked to PDMWorks so a simple Access Database would require a strict adhearance to policy. Any suggestions??
3) In PDM Vault Admin I mapped a custom property named "DetailNo" Then in SW/PDMWorks I selected it to be displayed after the file name as a custom Label Option. I get empty brackets <> but the detail number itself does not show up. However when I view the property itself it is there. Any thoughts as to why this isn't working? I just want to see the File Name / Description / Detail Number
thanks for your help
A few questions??
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
RE: PDMWorks using dumb file names
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
I do a ton of Prototype Tooling design to make prototype parts in very small quantities.
I may have 1 complex medical part that requires 10 single stage tools to fabricate. Each tool being a different operation. What makes things complex when it comes to smart file-names is that I often use SW tooling parts and assemblies from other projects for a new project. So I am constantly mixing and matching detail components to expedite the prototype development. So a sequential dumb file name structure seems like it will work well. I have been experimenting with a couple of jobs that are already complete In PDMWorks by renaming the files manually to see what works well and what doesn't.
So far, sequential totally dumb file names seems best. I can use properties to describe the tool component, and also to list customer part numbers that a tool is used for.
If I had a single tool dedicated for a single part then I could use just about any file name method I choose.
Tom Malinski
Now that I have a better understanding of what it is you're dealing with, it makes sense to me. It's basically how we do things here. While the file name is actually the part number, it is a 'dumb' number, a place holder. The description let's people know what 'it' is. That, IMO, is how it should be...
Jeff Mirisola, CSWP
CAD Administrator
Chris
AutoCAD 06
Any suggestions as to my 3rd question in my original post? The custom property does not show up as a Label after the file name in PDMWorks
Tom Malinski
Tom Malinski
