saving a cad drawing to a pdf file
how do i convert a cad drawing so it can be viewed as a pdf file? i have auto cad lt 2007 and a standard version of pdf viewer.
thanks in advance
RE: saving a cad drawing to a pdf file
Just print it out as as a *.pdf file.  When the AutoCAD print window pops up pick the Adobe program instead of your normal printer.
Hope this helps.
You have to buy software to do that.  I use Adobe full version but here are lots of choices.
Acrobat Pro will also allow you to save as PDF with the layers intact so they can be turned on/off.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Have you tried DWGgateway? It is a very handy tool.
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
thanks for all the help, i managed to do it using the plot option and printing it to file and changing the print option to dwg to pdf! thanks for all the help!!
You can also use a free program called pdf995.
It has worked very well for me.  Just use it as the printer choice, it will let you choose the paper size ...etc.
regards,
Use Foxit progam
I can second PDF995. We use it throughout the department.
Using AutoCAD Mechanical 2006, UGNX4, XPsp2, MSOffice 2K3
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
