STL & FeatureWorks 2007 failure
Hello to everybody,
I've tried to import the STL file generated from eDrawings viewer to SW, and got the graphical data in the SW part. Now I want to get a feature tree using FeatureWorks 2007, but neither automatic nor manual recognition doesn't work. I don't understand why, cause, according to FW Help, it CAN understand the STL format. What can I do in this case?
Basil.
RE: STL & FeatureWorks 2007 failure
STL models are too fragmented to use any kind of feature recognition.
Basil,
You can set options during import to create geometry (as opposed to creating a graphic body), but Featureworks won't recognize anything.  If all you have is an STL file you're going to have to re-model the part to have a feature tree.
gellmar,
Did this part come from a customer/supplier or is it something you created? If it was sent from the customer or an outside source, ask for a STEP or an IGES file. Featureworks will work on exported models like that. STL files are best used for when you need to do rapidprotyping.
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
Intel 2 Duo Core, 2GB RAM
nVida Quadro FX 3450 512 MB
