what is LMS software , can i get a trial version
I i do not know LMS but can i have get a trial version that i can view and see how user friendly it is.
thanks
sd
thanks
sd
RE: what is LMS software , can i get a trial version
As to what it is, well, if you don't know why do you want to evaluate it? It is a powerful signal acquisition and analysis suite, widely used in the automotive industry, for things like modal analysis, rotating machinery analysis, noise path analysis etc etc etc.
I would add that it is probably the most expensive of the alternatives, and the annual licensing fees are in due proportion. On the other hand it definitely works, is stable, easy to use (though frankly if you've used one of these programs there is not much difficulty in using another) and is powerful, at least under Unix.
Cheers
Greg Locock
By the way, anybody knows about cheaper softwares/systems for general purpose dynamic analyses? Thanks, bye.
It is a lot easier to customise then the LMS stuff, and the support costs are less unbearable, and the aftersales support is excellent. It still costs a fair bit if you want a high end analysis system with all the bells and whistles. Their demo works on a normal PC.
Another option would be the latest B&K incarnation (Pulse/Artemis, I think). We use B&K transducers into Prosig a/d direct to laptop, then analyse the data on Prosig or dump it to the Unix boxes and use LMS for the advanced stuff. Our modal analysis is all done on the LMS boxes.
Cheers
Greg Locock
Bear in mind that it only supports "top end" acquisition hardware and that costs money! User support it excellent.
Michael
Cheers
Greg Locock
i would like to do a project using lms software ,so is it possible to do the project using this software.
Good Luck.
Someone can help me!
Michael
I ahve seen much discussion about the testing side(Data acquisation and analysis), what about the CAE side?
LMS is having High end CAE modules for Vibro-acoustic modeling & analysis. Sound radiation from structures,scattering of sound waves and transmission of sound waves along the structures can be predicted at the design stage itself.We can get wide variety results such as acoustic pressure distribution,particle velocity,sound intensity,sound power,etc.And also structural & acoustic modal parameters,modal participation fators,panel contribution can be calculated in much better manner.
I think LMS is the only comapny involved in both testing & CAE software.
Hear to the sound at the design stage itself.
But it is a numerical tool to be used with caution, understanding it's capabilities & limitations.
With Regards,
elogesh
