DIN rail regulators
DIN rail regulators
Does anyone know of a DIN rail mounted regulator that can accept 12V and supply 7.5V at 1A? Linear or switching it does not matter (except cooling might be a problem if linear)
RE: DIN rail regulators
Gunnar Englund
www.gke.org
Dan - Owner
http://www.Hi-TecDesigns.com
7.5V is not going to be common. Look for one with an adjustable output voltage that will cover that within it's range. Those in dpc's link should fit the bill however, if you get the 8V unit and adjust the output.
regulated 0.5v overvoltage.
Sounds like a device that has a 5volt regulator of its own inside..
Keith Cress
Sometimes I only open my mouth to swap feet...
Keith Cress
