Transform a Matlab code into a VerilogA code to use under cadence
I have a Matlab model of an antenna.
I need to transform the code into verilogA code to use it under cadence.
Using Simulink® HDL Coder 1.1 was recommanded, but for using that tool box, I should use embedded matlab code, which reduces the flexibility of the code, functions couldn't take more than two variables...
Any suggestions on how to fix that problem?
