Flow Meter Placement
When designing a flow control run in a pipe, where would be the ideal place for the flow meter? Upstream or downstream of the control valve?
Do the flow rates make a difference? What about the fluid?
In this case I am controlling the flow of steam to a reboiler that is currently on temperature control. The addition of a flow meter will allow us to switch between temperature control, flow control, or cascade temperature-flow.
RE: Flow Meter Placement
I would have the flow meter on the steam line for information (and accounting) purposes, but wouldn't control off of it. Steam is tough to get a reliable (for control purposes) flow reading. It probably won't go to zero properly, either. All of this introduces error in your control loop that can be avoided.
Use the normal meter run location guidelines. Include the weep hole at bottom of plate if using an orifice plate in horizontal run. Include a condensate removal upstream of the orifice to get better metering and control.
best wishes,
sshep
This is in the troubleshooting stage. We are also controlling condensate in the reboiler by putting two steam traps in parallel (instead of just one) going to a condensate pot with level control.
