Inserting PDF's into AutoCAD LT 2008
I am using AutoCAD LT 2008
You can insert an Ole obecjt (in my case PDF) into model space, which seems to work.
When I save the drawing and then open it again the PDF has turned into a black white sheet.But in the preview window before you open it shows
Has anybody else done this? how can I save the drawing so I retain the PDF
Thanks for your help
RE: Inserting PDF's into AutoCAD LT 2008
I don't have 2008, but I think it don't work.
You have to convert the pdf as a raster image, dxf etc...
Lothar
ADT 2004
