Vickers Hardness to Yeild strength??
We are trying to determine the yeild strength of steel using Vickers Hardness number.  I was told this is possible but am unsure.
Is this possible and if so where can I get the information?
Any information is gratefully appreciated!
RE: Vickers Hardness to Yeild strength??
I have seen two micro indention methods of determining both yield and tensile strength.
One involves using two indentors that are actually moved sideways slightly.
The other one measured load vs. depth for a series of indentions.
While these both involve micro indention neither one uses a standard machine.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
EdStainless,
Is there a publication on this method?
All,
Thank you for the information. I will ponder on it over the weekend.
