Cable type for cement factory
Hi every body!
I have a small problem and would like to refer to your opinions.
At the moment, I am supportting to a cement factory for medium cable, 6kV. They use 6kV-2XSEY - 3x240+25mm2 the the project.
I wonder how the forth wire(25mm2) be used, for the safty or other reasions?
There are any special purposes for this type of cable?
How to specify, definte the forth wire?
Is there any recommendations?
Thank you for all your support
