close profile - view commands
Hello!
Another amateur question:
Several times, I sketch a complex profile that includes lines, radius, etc. When I try to use it as profile for cut or extrude, the message that the profile is open or self intersecting comes up. Up to now, I go back to sketching and trim everything by hand. In other similar programs, there is the command "close profile". Is there anything like this in CATIA ?
2) I cannot place the command "insert plane" on the workbench and keep ot there whenever I open CATIA. How can I do this ?
Thank you
Thank you
RE: close profile - view commands
In addition to "close profile": In my opinion, there isn't such a command. I missed it too in older versions, but till now (V5R8) I never had this problem.
Best regards
For you information:
In the Sketch Analysis, you have the possibility to close automatically your profile.
Select the Button -> Close Opened Profile
But first you have to select the related profile in Detailed Information Line.
Good luck.
