VehDyn Damper
VehDyn Damper
VehDyn Damper
I am working with a parametric model of a military vehicle and trying to visualize the data I am managing. Does anyone know how to construct a Force-Velocity plot for the dampers used in VehDyn (part of NRMM)? The parameters I have access to are:
MaxDampingForceJounce
InitialDampingSlopeJounce
DampingBlowOffForceJounce
MaxDampingForceRebound
InitialDampingSlopeRebound
DampingBlowOffForceRebound
It seems like there are missing parameters (specifically the max velocity or the slope after blow off). This should be a bilinear curve in both compression and extension. Am I daft? A Google search did not turn up anything useful for me.
Thanks in advance.
Best regards,
Matthew Ian Loew
www.cometsolutions.com
RE: VehDyn Damper
You need at least 8 parameters, so they must make assumptions about two velocities, at a rough guess
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
