Pipe flare dimensionning
I need to do a 2d drawing of a pipe with a flared end. This is for fabrication....
Can anyone tell me how to properly dimension a Flare on a pipe. Is it done by a note or actual dimensions? What are the rules, standard, etc...
Maybe you can redirect me to a source on information.
Any help is appreciated.
Thank you
RE: Pipe flare dimensionning
engtobe,
The pipe with a flared end would usually be a cold formed lap to be used with a backup flange, like the fabricated lap or flared lap per ASME 31.3 para 306.4.2 which states (b) the outer diameter of the lap shall be within the dimensional tolerances of the corresponding ASME b16.9 lap joint stub end.  (Also see B31.3 Fig 328.5.5 for fabricated laps.)
The pages 15 and 29 of B16.9 have the lap O.D. "G" that corresponds to the raised face diameter of that size pipe  flange.  (Thickness of the lap is required to be at least 95% of the minimum pipe wall thickness, multiplied by the ratio of pipe O.D. divided by the diameter at which the thickness is measured.)
