Penetration problem
Penetration problem
Penetration problem
Hi everybody
My name is Okapi and i'm new on this forum.
My english is not perfect, because i'm not native speaker...
I have a probleme to analyse a not penetration surface
Please, look the programme and modify the programme to have not penetration surface (i looked with TARGE170 et CONTA but i'dont do that)
thank you
!               Penetration problem
fini
/clear
/title,toto
/gra,full
/vie,,-1,-1,1
/vup,,z
/type,,4
/prep7
/num,1
tnum,1
btol,1e-5
epsi=1e-4
!Définition du fichier de plots de sortie
filplot='toto'
taille=0.005  !taille des elements
!Définitition des éléments
ET,1,63    !plaques mécaniques structure
r,1,0.8e-3
!Définition des matériaux
!Mat1
dens,1,3000
ex,1,20000e6
nuxy,1,0.33
!Mat2
dens,2,1000
ex,2,70000e6
nuxy,2,0.33
!            Géométrie
allsel
csys,0 $ wpcsys,-1
rect,0e-3,20e-3,0,200e-3
csys,0 $ cloc,11,0,0,0,2e-3,,, $ wpcsys,-1
csys,0 $ cloc,11,0,0,0,0,,90, $ wpcsys,-1
rect,0e-3,20e-3,0,2e-3
csys,0 $ cloc,11,0,0,200e-3,0,,90, $ wpcsys,-1
aplot
allsel
nummrg,kp,1e-6
!Mesh
csys,0 $ wpcsys,-1
asel,s,loc,z,0
esize,2e-3
type,1
mat,1
real,1
amesh,all
csys,0 $ wpcsys,-1
asel,s,loc,z,2e-3
esize,2e-3
type,1
mat,2
real,1
amesh,all
csys,0 $ wpcsys,-1
asel,s,loc,y,0
esize,2e-3
type,1
mat,2
real,1
amesh,all
csys,0 $ wpcsys,-1
asel,s,loc,y,200e-3
esize,2e-3
type,1
mat,2
real,1
amesh,all
nummrg,kp,1e-6
*get,NUM,node,,num,max
!analyse modale
csys,0 $ wpcsys,-1
esel,s,mat,,1
nsle
nsel,r,loc,y,0
d,all,all,0
csys,0 $ wpcsys,-1
esel,s,mat,,1
nsle
nsel,r,loc,y,200e-3
d,all,all,0
!Calcul de la solution
/solu
allsel
antyp,modal
modopt,lanb,10,0,2000
mxpand,10,0,2000,no
outpr,,
/out,outtoto,lst
solve
/out
/post1
set,1,3
/view,,-1,-1,1
/title,MODAL ANALYSIS - Travail
plns,u,sum
RE: Penetration problem
you should describe your problem with more details. From your input code I see, you are doing a modal analysis of two metal sheets bounded together at the two ends.
I assume, that you want the 2 sheets to collide with each other when vibrating.
This can not happen in a modal analysis due to the linear nature of the problem.
If you don't want penetration, the you must use contact or gap elements and do a transient analysis.
Alex
Alex,
Thank you for your answer
You understand my probleme
But, i don't use gap element, i use ANSYS since 2 week...
Best regards,
Okapi
