obtaining U stamp
obtaining U stamp
I work for uk vessel fabricator - ISO 9001 and PED certified.
We are looking at obtaining U stamp and would appreciate comments on the difficulty of this and how long such certification takes. We generally sub contract design, NDE (though I am qualified mech eng and have done many vessel designs) does this affect difficulty in certification?
Does any one have experience of how PED 97/23/EC can be related to U stamp. Many thanks
RE: obtaining U stamp
The U stamp is related to ASME VIII, the American Code and is not related directly to the PD5500. The current ASME VIII require you to obtain U stamp certification from the ASME Board. They will issue to you, based on extensive testing of your design and fabrication capability, experience and understanding of the current ASME code requirements. No specific PD 5500 requirements.
Please note that this month is due out the new ASME VIII re-write, which seems to bring major changes in the area of certification and perhaps in the area of U stamping also. Please be patient for a little longer and hopefully, the new Code will clarify for you the marking requirements.
gr2vessels
I'm trying to get a feel for how difficult U stamp is to obtain, knowing the experience that we have in uk fabrication (we have made non-stamped ASME vessels as well). Testing understanding of ASME code sounds daunting I assume this includes IX. Can parts of code for which we have little experience be specified as undertaken by 3rd party?
Go to "About Us" or call 44-1260-275305
This guide can be found here: htt
There are three kinds of people in this world; those who can count and those who can't.
PED 97/23/EC is the deirective that you have to follow for pressure veseels to be used in the EU.
PD5500 is the British pressure vessel code.
You can use ASME for PED 97/23/EC. There was talk of an Appendix Z that would identify the elements of Annex 1 and how they are dealt with in ASME.
Essentially you use ASME VIII the same way you use PD5500, EN 13445, AD-2000 or Stoomwezen.
One thing to be wary of, in the same way that PED Notified Bodies are stricter in the US than they are in Europe, ASME Authorised Inspectors are stricter outside in Europe than in the US.
The key, as always, is attention to detail. Follwo the code implicitly and you'll produce safe and effective U-Stamp vessels quite easily.
